Chris Calli It is not impossible to get past the Gmail account on any phone. You do NOT have to know the email or password to get past the Google lock on the LG 4GLTE phone, you simply Google the FRP LOCK on that specific phone, in your case you said you got the LG 4GLTE PHONE SO YOU GO TO YOUR GOOGLE SEARCH ON A DIFFERENT DEVICE THE TYPE IN "FRP LOCK FOR LG 4GLTE PHONE" It will then give you multiple videos on different ways to get past any Google locked device even if you do NOT have the email or password for it. Hope this helps
What is your gmail address, that is what is needed.
SOURCE: My Samsung gt i5500 was asking for my Google
Try this first in this order: Press Volume UP + Volume Down + HOME button together + power on for 2 sec until recovery menu. Use Vol keys to highlight wipe data. Press to confirm then select reboot now. If this method not working see other methods below...
(ALL DATA WILL BE ERASED FROM THE PHONE AND IT WILL BE BACK TO THE FACTORY SETTINGS), PRESS AND HOLD POWER BUTTON + CALL BUTTON + VOLUME DOWN. FOLLOW THE INSTRUCTIONS ON THE SCREEN AND YOU ARE GOOD TO GO.
• When the device is turned off, simultaneously press the Volume key up and down, and then press [END CALL]. When an exclamation mark appears, press the Home key to reboot.
Thank you for using fixya
SOURCE: I gave my friend my LG Optimus Dynamic
1. Power down the phone then remove/reinsert the battery to ensure that the device is completely off
2. Press and hold the following keys for 10 seconds: Volume Down + Home Button + Power Button. Release all 3 keys when the Android Recovery Menu pops up
3. Press Volume Down to scroll down and highlight "wipe data/factory reset"
4. Press the Menu Button to select
5. Press Volume Down to scroll down and highlight "Yes - Delete All User Data".
6. Press the Menu Button to select
7. After data wipe is complete simply highlight "reboot system now" and select it by pressing the Menu Button.
SOURCE: Android ascend locked and asking for google
consumer.huawei.com/en/mobile.../support/.../p6-u06-en.htm
www.huaweidevice.co.uk/support/
you can most likely set up your own email address via www.gmail.com to sync the phone to a new gmail email.
it is needed on android phones for the google store !
This is an activation lock through Google. Basically, the device was factory reset, and there was a PIN or SWIPE lock screen and a Google account on the device when it was factory reset.
As a layer of protection and to ensure the phone is not stolen, it is looking for you to enter the Google account that the device was ORIGINALLY set up with. If you know the Gmail login, but need to reset the password, you will not be able to login to the phone for 72 hours AFTER the password reset.
If you do not know the login, there is no way to bypass this screen. You would need to get the Gmail account information from the original owner.
If you have more questions concerning this, here is an in-depth explanation of the security lock. Guide What Is Android 5 1 Anti Theft Device Protection Feature And How Do...
I’m happy to assist further over the phone at https://www.6ya.com/expert/christopher_d13aca62d29ed9ae
