SOURCE: Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel.
SOURCE: LG WFT1391TP Top Load Washer - Black Clay Pieces in Drum
Caustic soda. Be careful to wear gloves. Fill tub with water, cold will do, put in about 100gms of soda and turn on a extra large wash cycle only. Don't let the water drain, allow to stand over night, then complete wash cycle. You will find that hugh amounths of lint come loose. Repeat if necessary. I now do this about once every two months. Another thing to remember is to always leave lid open when machine is not in use, this prevents musty smells.
I have become obbsessive in sorting out the problems discussed and am now looking for a service manual for a WF-T7014PP as i want to remove the pulsators to ensure ther is no lint stuck in there. If anyone can assist please mail to [email protected]
SOURCE: Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
SOURCE: SPEED QUEEN WASHING MACHINE LEAKS WATER WHEN IT STARTS WITH WASHU
check hoses and pump area.
SOURCE: Replace Water Pump on Speed Queen Washer
did you look at the front panel if you tip the machine to the back and look at the bottom of the panel you will see 2 hex head screws remove them and lift the panel out and slide it down some machines others you have to remove the top
