SOURCE: panasonic kx-tg2740 cordless phone - how to change message?
i found this i hope it helps
SOURCE: i have the panasonic kxtc1175bxb cordless phone pair the handset
sorry, it seems that they have no manual for this model online yet. however, the procedure to reset handsets might work if you go to page 35 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf") good luck!
SOURCE: panasonic cordless won`t dial with magic jack
Turn off your LOCAL AREA CODE entry in the Panasonic... Magic Jack WANTS the area code to ALWAYS be dialed... so store incoming caller ID's with the AREA CODE INTACT and dial only from numbers with an area code displayed. Worked for me!
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
SOURCE: Trying to download user guide for this phone
http://www.retrevo.com/support/Panasonic-KX-TGA101-Telephones-manual/id/2878dj085/t/2/
i think i helped u,,best of luck
