SOURCE: I have a Sherwood RX-2030R,
Check Sherwood RX-2030R specification of AM tuning frequencies limits in user manual.
Please confirm was it tune before below 1320 and above 1710 AM meter band?
SOURCE: PS-T3 connection to Sherwood 4105 Receiver
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
SOURCE: How do I set up an iPhone 3G Bluetooth connection?
first go to settings, general, bluetooth, make sure it is on, then try your toyota steps. good luck
SOURCE: technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
SOURCE: Iphone won't work with bluetooth in mazda 3 2010
iPhone has had bluetooth since the first model in 2007. With iPhone OS/firmware 3.0 (free for all iPhone users), iPhones are fully A2DP compliant and link with Mazda bluetooth.
My current experience is with a 2010 Mazda3 and iPhone 3GS, where I get phone and iPod functionality via bluetooth (yes, without jailbreaking), though the steering-wheel controls are limited to play/pause and volume only.
