1.Check the LED light
Generally speaking, the LED light will start blinking when you connect the charging cord and charger to your Bluetooth speaker. Like the EasyAcc Mini 2 Portable Bluetooth Speaker features a 360 degree LED light which wraps around under the top metal and indicates the charging status. If the light is broken, probably the speaker is charged for real but the light says the opposite. If this is the case, try to turn it on after 1 hour's charging, if it works fine the LED light is broken for sure. It's not completely handy to use the defected Bluetooth speaker but at least there's no other system problems encountered.
2.Switch the charging cable and adapter
It has a great chance of applying broken cable or charger when the Bluetooth speaker not charging, therefore go to switch them to identify whether they are at fault or not. If so, directly replace them to qualified ones.
3.Clean charging port
Chances are that the charging port is choked with lint, dust and dirt. A can of compressed air can blow out the offending irritants and get your USB connection back to normal. If the charging port becomes loose, do not try to fix it by yourself if you don't get any experience with the tools like pliers or tweezers. Go to ask customer service or someone with solid skills for help.
4.Update/Reset software
The dead battery issue also occurs when the software is out of date, the manufacturers regularly release the updates or upgraded drivers to solve the corresponding problems. This happens on lots of rechargeable devices out there and there is usually a fix.
After all, if still says not charging, contact the after sale customer service and get support immediately or get it replaced under warrenty.
