The engine shuts off about every 7 days.i have a 1996 delta 88 oldsmobile
SOURCE: 1999 Oldsmobile Delta 88
seriuosly? refer to a haynes car repair/maintence manual. a lil messsy and a lil time but yes you can do it fram oil filters and mobile 1 synthic oil are the best to use.
SOURCE: power antenna on my oldsmobile 88 will not shut
Fault is within the power antenna unit. Needs replacement. If you dont mind the mast being up, it can be disconnected , in order to stop the motor running. Car washes will damage the mast in the event it stays up. Hope this helps.
SOURCE: engine check light is on
does the car buck on the highway when accelerating under a slight load?
i owned one of these exact cars,3.8 litre.
2 problems. one,the baffles braek in the gas tank,and if you run 1/4 tank or less it will stall in a turn.
mine it was a right turn.
2nd problem,the EGR valve was stuck and it would surge or "buck" on the freeway.
replaced the egr (exhaust gas return)valve and it ran like new.
if the egr valve is code 42,(i do not have the manual in front of me) you have found the problem
check the egr,it can cause the problems you have.
SOURCE: MORACHIS 1996 88 OLDSMOBILE STALLS
The problem sounds like the solenoid that locks up the torque converter. This will not set a code or turn on the check engine light. The car will restart each time after it stalls. This will happen when you are comming to a stop or turning a corner. At times, you can start the car in neutral but when you put it in drive or reverse, it will again stall.
This can also happen after you have driven the car and parked it. When you restart the car, it may stall when you try to drive it because the solenoid is still locked from when you pulled into the parking spot.
Try to free it up by driving the car about 32 mph in drive (drive with the square around the D) where the overdrive and lock up torque converter will work. At 32 - 34 mph, pull the shifter down to the next Drive (D without the box around it) and you should feel the bump of the torque converter unlocking. Then put it back into the upper drive location and you will feel it lock up agian. Repeat this about 20 times and see if this does not help. These can start becomming mechanically "Sticky" and cycling them 10 - 30 times can help.
There is also a 6 wire connector on the forward (front of the car) side of the transmission. This connector might be dirty. Clean it with electrical contact cleaner (spray type) and reconnect it to the transmission. This connector is probably not the problem but worth lookign at anyway.
There is also a small port in the valve body of the transmission that if plugged, it can cause this problem. I feel it is most likely a "Sticky" soleniod that locks up the torque converter and makes the car stall just like comming to a stop in a standard transmission car without pushing in the clutch.
Good luck,
SOURCE: 1983 Delta 88: how much MPG does a 1982 Oldsmobile delta 88 royal...
Personal experience between 13 - 20 for most models with the v-6 and v-8. the 5.7l is about the most fuel efficient at roughly 17
Hello
When the service engine
soon light (Also called the check engine light or engine management
light) is turned on this is to alert you to the fact that Powertrain
Control Module (computer) has detected a failure somewhere in the
systems it controls you may not feel any difference in the way the
engine runs, this can be the transmission or the engine or emission
system, there are fault codes set in the modules memory for these
faults. What needs to happen now is to have the powertrain control
module scanned with a special tool called an OBD2 electronic engine
control scanner or a OBD2 code reader. Once the code(s) are read then
you must perform the diagnostics for each code and make the
appropriate repairs based on the findings of the diagnosis that was
performed, this is called doing "Pinpoint" testing.
