Can I download a users manual for a Kenwood DP-R4070 CD player?
1helpful
Why not show CD track info on Kenwood c-h7 using dp-mh5 player? what error ? what should check?
The issue with not showing CD track information on your Kenwood C-H7 using the DP-MH5 player could be caused by several factors. To resolve this issue, you can check the following:
  1. Compatibility: Ensure that the DP-MH5 player is compatible with the Kenwood C-H7 unit.
  2. CD format: Ensure that the CD is in the correct format and meets the requirements for playback on the DP-MH5 player.
  3. CD read error: Make sure the CD is clean and free of scratches, as these can cause read errors that prevent track information from being displayed.
  4. Connections: Check the connections between the DP-MH5 player and the Kenwood C-H7 unit to make sure they are secure and properly connected.
  5. Software/firmware: Make sure that both the DP-MH5 player and Kenwood C-H7 unit have the latest software/firmware installed and are up to date.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service.
I have a Kenwood Multiple CD Player DP-M993 6 Disc Player and need to know the Unit Number for the Remote Control
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjXgKW8mOr6AhWFpokEHR7dCO8QFnoECA8QAQ&url=https%3A%2F%2Fwww.vintageshifi.com%2Frepertoire-pdf%2Fpdf%2Ftelecharge.php%3Fpdf%3DKenwood-DPM-993-Owners-Manual.pdf&usg=AOvVaw3Egktp5e2PKVgF8ppDrztX
My dad has a kenwood multiple compact disc player dp-mh5 that the disc tray randomly won’t open on, any suggestions on what to try?
Hello Skye, the Kenwood Multiple Compact Disc Player DP-MH5 of your dad, has a problem with a strap inside the mechanism, I suggest you take it to a specialized technical service
If you have technical knowledge, I send you the link to download the service manual, on page 16, the breakdown of the mechanics appears and shows you the belt with the number 46, that is the one that you must replace
I also sent you the link to download the user manual
Greetings Franco Dosil
Hola Skye, la Kenwood Multiple Compact Disc Player DP-MH5 de tu papa, tiene un problema con una correa dentro del mecanismo, te sugiero que la lleves a un servicio tecnico especializado
Si tu tienes conocimientos tecnicos, te envio el link para descargar el manual de servicio, en la pagina 16, aparece el despiece de la mecanica y te muestra la correa con el numero 46, esa es la que debes reemplazar
Tambien te envio el link para descargar el manual de usuario
Saludos Franco Dosil
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Kenwood-DPMH-5-Service-Manual.pdf https://www.manualslib.com/manual/203920/Kenwood-Xd-8551.html?page=17
I want tohook up a Kenwood KA-88 Amp. to a KT-58 Tuner to a DP-M5540 disc player and KA-68W Cassette deck. how do I do it?
Find the manuals or go by the basic INs to OUTs rule. REC = OUT, Play = IN. "Tuner" and "Aux/CD" are not literal. They're for anything BUT a turntable. But remember ONLY a turntable would ever use "PHONO".
This picture shows the rear of the KA-88
http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=168328&image_id=1469879
Register and download the CD manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-DP-M5540-CD-Players-manual/id/479ag101/t/2/
Users manual kenwood kdc-1020 cd radio/cassette player
You can download and print the instruction manual for kenwood kdc-1020 in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
1helpful
2answers
Kenwood stereowith A-58 Amplifier, no manuals, so can't set up
mine does the same and it cost 100 pounds to have the output chips replaced
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
