There are many effective ways to copy text from PDF to word, but the easiest way is to use OCR text recognition like bitwar text scanner.
As everyone knows that the content in the PDF file is unable to edit or change due to the file format, therefore many users will try to copy text from the file by using PDF Converter to convert the PDF to Word format.
Method 1: Adobe Reader Dc on Mac/Windows
Part 1: Acrobat Reader Dc on Mac/Windows
Adobe develops the Acrobat Reader Dc to provide multiple PDF tools for PDF users to edit PDF files more easily and efficiently. Therefore, users can use the software to extract text from PDF, but the price for the software license is quite high.
Step 1: Start the Adobe software and select Select Tool.
Step 2: Please Highlight the Text from the PDF that needs to be copied.
Step 3: Tap on Edit and choose Copy or press Ctrl + C / (Command + C for Mac users) on the keyboard.
Step 4: Open the Word file on Microsoft Word. Right-click and select Paste or press Ctrl + P/ (Command + P for Mac users) on the keyboard.
Part 2: Older Version of Acrobat Reader
Suppose that the Acrobat Reader Dc is an older version, please follow the steps below to copy text from PDF :
Step 1: Open the software and select Graphic Select Tool.
Step 2: Next, go to the menu and tap on the Text Select Tool to extract the text.
Step 3: Select the Edit menu and Take a Snapshot.
Step 4: The Camera Icon will appear in the software and use it to Crop and Extract the text.
Method 2: OCR Text Scanner
Besides using the Adobe Acrobat Reader Dc, users also can use the other alternative tool to extract text from PDF, which is the OCR Text Scanner.
Step 1: Open the PDF file and go to the text content page.
Step 2: Launch Bitwar Text Scanner and choose Screenshot OCR.
Step 3: Crop the content and Extract the PDF text.
Step 4: Copy the Result and paste it on the Word file.
Hello. If you are looking for a professional tool which can convert PDF to Word, try LightPDF. This is an online program that can work on different platforms such as Mac OS, Windows PC, Android and iOS devices. Make sure that you have a browser with you and your device is connected with internet connection
https://lightpdf.com/
Have you ever received a PDF file that you would like to convert to a Word DOC or DOCX format? Typically this is necessary when you have PDF that you want to edit the contents of a bit, maybe a resume or a thesis, but of course the PDF could be more complex. If you're looking to convert a PDF into DOC, DOCX, RTF, or TXT format, we'll cover a few options to get the extraction job done in Mac OS X. This is basically the opposite scenario of converting a Word doc to PDF via Microsoft Office Word app, but it's just as frequently necessary.
First we'll walk through how you can use Google Docs to convert a file to Word format, then we'll who you how you can potentially extract the text from a PDF document which you can then turn into DOC or DOCX on your own. Next, we'll show you a paid solution from Adobe which is a thorough and complex PDF to DOC converter tool that is best used for professional applications, and an alternative native Mac app which offers similar functionality. Finally, we'll cover a more automated method that is an extension of the first text extraction approach, which can convert PDF to text files that you can edit, which is perhaps most appropriate for casual uses and with simple PDF files.
Professional HP Printer Scanner Support to Fix Technical Issues
Steps to convert the PDF file into Word in Mac:
1. Tap the open button on the welcome screen.
2. Click the convert button on the top right window.
3. A dialogue box will appear where you can add more no. of documents and choose the specific page or no. of page to be converted.
4. Choose word document from the drop down menu. If your pdf contains editable texts or images you can continue making changes to the text and images after the conversion but if your file is scanned pdf i.e your file does not containing
texts and images to be edited.
5. You will be needing to tap the OCR button at the bottom of the window.This will ensure that your document will be transformed into one and can't be edited.
6. Click convert to complete the process.
7. Output will be converted file from PDF to Word.
Thanks!
Testimonial: "I don't think I know exactly how it works. Can you tell me more detail about it."
Down load the adobe program compatible with mac o.s
As we all know , PDF is a proprietary format that allows we to
read electronic documents, either on or off line. But the problem is that it can not be editable and
freezes the content . Facing with such problem, we need to convert pdf files to
other formats. While, we always convert it to word , we all familiar with word
which is an editable format .As mac user, you must want to know how to convert
it perfectly, in this case , PDF Converter Mac is the best choice for you.
To begin with you should know the software which is called PDF Converter Mac, PDF Converter Mac is a comprehensive PDF tool to help Mac users
convert PDF to Microsoft Office Word, Excel and PowerPoint for Mac. By
converting PDF files to Office documents for Mac, Mac users can flexibly edit
or reuse read-only PDF files, or extract PDF tables and data to spreadsheet for
easier calculating and editing, or present PDF contents to the public. PDF Converter for
Mac offers many amazing features: Good Preservation; High Efficiency; Support
encrypted PDF Files Conversion; Flexible Options and more. With quick
conversion speed and batch conversion modes, PDF Converter Mac can improve your
efficiency to a large extent.
Now download this PDF
Converter Mac to convert pdf to word on a Mac and install it to your computer,
Following is the details on how to convert pdf to word step by step.
step 1. Import PDF Files
You can add them from the File menu or directly drag files
into the panel. By the way, you can remove the file by dragging it out of the
panel.
step 2. Customize Output Settings
You can set the files in the panel individually. Choose a
file and click setting icon and you can customize the Page Range
and Format.
The default option of Page Range
is All pages; you can also choose Customize and type on the page number that
need to convert.
There are two options of output format. You can choose MS
Office Word (.doc) or Rich Text Format (.rtf) as your need. If you choose the
option Apply to all, the format of current document setting will apply to all
the files in the panel.
step 3. Set Destination Folder
You can set output folder by choosing File-output
settings-output folder. There are two options to select. You can save the
output file in the same folder as source or click Browse to customize the
destination folder.
step 4. Convert PDF Files
Click Convert and all the files will be converted in
seconds. There is a processing bar in the process of conversion. And after
conversion, there will a notification to show you the conversion result. It
will be found that all the original text, layouts, hyperlinks and graphics
would be preserved in an editable Word document.
OK! You successfully
complete to convet pdf to word in mac OS X with a few steps, you can use the
word files easily now.
