Dryers Logo
A
Anonymous Posted on May 30, 2018
HONEYWELL HS1655TGD1 lights up, will not work.
The panel lights come on, but the fan blades will not turn.
1 Related Answer
Anonymous
  • 910 Answers
  • Posted on Jul 16, 2011
SOURCE: I purchase the Whispur 510
The first thing I would suspect would be the Starting Capacitor which give the Motor the kic to start.
As you've only just purchased it I'd say get it fixed under warranty but if you want to have a look at it yourself you could try the following.
Turn the unit on and try and spin the Fan manually with a stick as if it starts it could slice your finger. If the Fan continues to spin then it is the Starting Capacitor thats failed.
If it doesn't the next thing to check would be with the unit turned on you're getting the correct voltage to the fan, but to do this you would need a multimeter. If the voltage is their then it's the Motor thats failed, if there's no voltage then it's the controller thats failed.
If you need any further assistance then just ask.
Can I replace the blade? Where do I get a replacement blade?
http://yourhome.honeywell.com/home/Applications/ReplacementPartsSearch.aspx
BROKEN BLADE OF TABLE FAN
obtain new blade and replace same.
https://yourhome.honeywell.com/home/.../ContactUs.aspx
1helpful
Fan blades not turning
First check all the breakers. Locate the breakers to the outdoor unit, turn them off, then back on. If that is not the problem, you likely have a capacitor blown to to power surge, or static charge from a close lightening strike.
Honeywell digital thermostat stopped working
Sounds to me like you have a low voltage short. If the stat had no display until you installed the battery means there was no voltage for the stat to work. Putting the battery in proves the stat works, no motors turning on probably leads to a blown low voltage fuse generally a blade fuse on circuit board in indoor unit. Good Luck
2answers
HT800 Honeywell Fan Has Two Screws that Can't be Unscrewed
Just bu a clean air can used to clean a computer desk top much easier.
3helpful
Cleaning a 14F0 Honeywell Fan
thank you for using fixya. The blade cage has locks and screws that you can remove from the back. once the cage has been removed, you can remove the blade attached to the motor using a vacuum cleaner or you can remove the blades by undoing the screw on the center detaching it from the motor.
3helpful
2answers
Hello,help please
My fan is doing teh same thing. I have been taking the cover off and spinning the fan blade manually. It takes about 1 minute of constant manual vigorus spinning but as soon as its warmed up the fan blade spins easy and just takes off and starts working. Im sure its not the safest thing to do but it does get the fan running for the rest of the night. Once the fan has been turned off for a while the blade is hard to spin again and I have to start over with teh manual process. I am thinking its the motor being I can manually get it started by spinning the fan blade and think I will check on the cost for a new motor
Honeywell HFD 135 FAN BLADES DIRTY
I used a can of compressed air to clean my fan blades and this did the job. I bought a 6-pack of 3M Dust Remover at Sams Club to save money. Hope this helps.
George
2helpful
Cleaning
turn the fan over. on the back you'll see ten holes around the circumference of the cage. use a torx screwdriver of the proper size and remove them. the front part of the cage will come off. the blades are a press fit over the shaft and locating pin. have someone hold the body and pull off the blade.
Top Honeywell Dryers Experts
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Honeywell Dryer Expert? Answer questions, earn points and help others
