Watches Logo
Lisa Lappe' Posted on May 29, 2018
What year is a bulova m6 10k rgp bezel serial # 826194?
1helpful
Bulova stailess steel 16 Diamond Bezel Chronograph Watch discolored on raised part of bezel like the metal is turning brown?
You can try a polishing cloth to see if this removes the discoloration, or very gently brush it with a toothbrush and mild soap ( very little water) if this does not help you will need to send the watch back to Bulova to their service center. 1-800-228-5682 is the Bulova service center phone number, call them for further instructions. Sometimes the discoloration is caused by certain chemicals found in lotions, soaps and cleaners. Hope this helps! thank you!
I have a Bulova Watch that was given to a Clark Candy employee with a Serial Number of 523791. Looking for what year it was made and is it worth anything
The value of your watch depends greatly on the model / style, age, and case composition. It goes without saying, but watches (of any mechanical quality) that have real gold cases right now are worth quite a bit more than watches with gold plated, gold filled, gold-tone, or stainless steel cases. Presentation watches like those given to employees upon retirement were often gold or gold-filled--but there's a world of difference in value between those two types of watches.
In terms of age, it's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1947 Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet:
http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
1helpful
I got a vintage Bulova. it has A404403 on the back. What website I can check its year?
It's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Older Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
I NEED TO KNOW YEAR OF BULOVA LADIES WRIST WATCH ITS 10 KT AND I HAVE A SERIAL NUMBER z78782. it has bulova ms on back
A Bulova "M5" code would indicate that the watch was made in 1965. Vintage Bulova watches can be dated by this little alphanumeric code:
Pre-1950 Bulova watches used a variety of symbols and numbers (e.g., 47 and 48 to designate 1947 and 1948) to show the model year of the watch. A chart of those symbols can be found here: http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
2answers
Need bezel with lugs
You could always ask the maker (go to Boluva.com and get the address of your nearest service center).
It seems s unlikely that they will be able to help with such an old watch but you never know your luck. I'm sure that they will be pleased to hear that your watch is still working after such a long time!
8helpful
3answers
How do I find my serial number on my bulova watch
Serial numbers are generally on the back of the watch.
You may be able to find two or three numbers on the watch.
A case number, a movement number and a serial number.Alternatively you might find a style number (which in your case is 26B44) and a serial number.
2helpful
Appraise Bulova N2 10K R.G.P. Bezel Stainless steel back
I have seen this watch sale in mint condition for as much as $40 but this is an inexpensive piece.
Sep 14, 2009 • Watches
Top Bulova Watches Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Bulova Watch Expert? Answer questions, earn points and help others
