Question about Dryers
Our Whirlpool dryer runs, then cuts out. After a
Our Whirlpool dryer runs, then cuts out. After a short time it will run again. Lately, it's been stopping and then re-starting all by itself. What's wrong?
  • 114 Answers
Sounds as if your motor is defective. It has an internal thermal switch which cuts the motor off before it gets too hot. After it cools, the switch makes up and the unit is able to run again.
Posted on Aug 01, 2009
6ya staff
SOURCE:
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Whirlpool GW9200L Gas dryer
The first thing to check is the door switch. It is a pretty common failure I am running into lately.
Post back with any questions.
Thanks/Mike
Jan 13, 2008 | Whirlpool GGW9200L Gas Dryer
Dryer still runs it just isn't getting warm
The heating element is wired in series with a thermal cut-off and a high-limit thermostat both located on the heater housing.The thermal cut-off blows open when the high-limit thermostat fails to cycle off in order to regulate the heating element temperature. When the thermal cut-off is blown, power to the element is cut-off and the dryer will not heat. Replacing both thermal cut-off and the high-limit thermostat if the former is indeed blown. Click on the links below for the troubleshooting and repair details.
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (Filter on Top with Removable Back Panel) Running But Not Heating
Troubleshooting Whirlpool and Whirlpool-made Electric Dryers (With Front Bottom Panel) Running But Not Heating
Jun 18, 2011 | Whirlpool Dryers
Dryer wont heat
The problem is likely the thermal cut-off and/or the high-limit thermostat if the dryer runs but doesn't heat. Verify this by bypassing the thermal cut-off and the high-limit thermostat. Click on the link below for the detailed troubleshooting.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers Running But Not Heating
Feb 18, 2011 | Whirlpool GEW9200L Electric Dryer
When I turn it on it will run for a short time and cut off.Like it is over heating when it cools down about 1 hour latter I can contuine drying intill it does it again
Good day,
There is a thermal device in the motor that will shut it off it it gets too hot. Once cooled down, it will restart.
Replacing the motor seems to be your only option.
If you want to replace it yourself, here is an excellent tutorial.
If the hyperlink fails to work, just copy and paste it into the address bar of your browser. Yes, it's a Whirlpool product.
Appliance parts houses that sell Whirlpool parts will have the correct motor.
http://www.applianceaid.com/wpmotor-change.html
Dec 11, 2009 | Roper REX4634KQ Electric Dryer
Whirlpool dryer model LGQ80000JQ4 starts to heat and runs then stops heating, but rest of dryer seems to run fine
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Whirlpool dryer, elctric runs but squeels. sometimes it stops squeeling once it's run for a while but lately it seems to do it the whole time. it does get quieter after it's run for a while
sounds like your "Drum Glides" need replacing, open the door and cheat the door interlock and you should be able to hear it closer by bottom of drum by lint filter if yours is located there depending on model
Jul 28, 2009 | Dryers
Whirlpool gas dryer, GGQ8821LL0 runs but does not heat up at all.
It's most likely your thermal fuse have you cleaned out your vent lately? if it is blocked you probably blew the thermal fuse or high limit.
Jan 07, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool Dryer has trouble drying (LER5620KQ1)
Hi rfairess
it sounds like the high limit thermostat is cutting out and not resetting itself.
Sep 16, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
59 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
