SOURCE: 10'' bench drill press model DP200 WON'T START
The belt has either come off the pulley or the belt is slipping. Open th top access hatch and check the belts . If belt is off replace and tighten , if it is just loose tighten the belt.If it is not the belt and the motor is humming but not turning you will need to replace the motor's starting capacitor.Good luck and please don't forget to rate this answer, Thanks
SOURCE: 1/3 hp drill press motor runs hot and very slow.
Look instead at the motor and drill post bearings. Remove the belt to see if the motor runs correctly with no load. If it still hums and gets hot, check that the motor itself turns freely (when off). If the motor seems to be ok, turn the driven pulley by hand--it should also turn freely. The capacitor is usually a starting assist, not running. To test, wrap a small rope several turns (when pulled must turn in the normal direction) around the small motor pulley and pull smartly while turning the motor on. If it now comes up to speed, the capacitor has lost capacitance. Electronic parts suppliers like Jameco or Mouser have such items.
SOURCE: ryobi spare parts
Unless you have the part in hand, which you could take to a specialized machinery or spring supplier to see if they could match it up, the only other way to get the correct part is to contact ryobi direct and talk to their parts department. They will be able to tell you the part number, and if available, send you one out direct from their warehouses.
Good Luck!
Testimonial: "Thank you very much for taking time to help! I have phoned Bunnings who I think are now the only suppliers of Ryobi in AU who are sending a spare. "
SOURCE: How do you correct excessive drill wobble on a
First you have to determine if it is the spindle or the chuck assembly. I would go to ereplacementparts.com and look at a breakdown for this tool so you know what the parts look like and then go from there. I couldn't find the schematic on the Ryobi site.
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
