O
Okwe inyang Posted on May 28, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
If fx =10x, for what value does fx=100,000. - Office Equipment & Supplies
k24674
Level 3:
  • Office Equip... Master 8,093 Answers
  • Posted on May 28, 2018
k24674
Level 3:
Answers
8093
Questions
0
Helped
4673195
Points
21595
X=100 000/10=10 000
Testimonial: "Options given are 10, 15, 20 and 5. Don't know how it is that because I also got 10,000."
  • k24674 May 28, 2018
    There must be an error in the function. 10x means 10 multiplied by x. However if the function is f(x)=10^x (10 to the power of x) then 100 000=10^5=10^x. Thus x=5.
  • Okwe inyang
    Okwe inyang May 28, 2018
    Thanks for the explanation,
2answers
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Is there a function for Linear Interpolation, if so, where do I find it? Thanks!
Sorry, I don't have that calculator, but let's see if we can work this out. "Linear Interpolation" means find the value of y for a given value of x from a line of best fit, within the range of values that you are given.
Hopefully, this helps. If not, let me know and we will explore more.
Good luck,
Paul
What is an Ma error casio fx-9860gii
Ma error means Mathematical error.
Check input values and make corrections to ensure that values are within allowed limits.
Please Check the manual for the calculator. It is available on the Casio website. Here is the link.
fx 9860G fx 9860G SD Calculators Manuals CASIO
How do i calculate the normal probability value, give z-value, on casio fx-82ms
The fx-82MS does not have any built-in functions for calculating the normal probability distribution or its related values. You can calculate it using the defining function or any of a large number of approximations. Alternatively you can look up the values in a table.
Some advanced calculators have the functions built in, and programmable calculators can be programmed to give them. Sadly the fx-82MS is neither.
For more about the normal distribution, see http://en.wikipedia.org/wiki/Normal_distribution
1helpful
2answers
I need to figure out how to calculate the hydronium concentration for a drink that has a pH of 3.1. I am told that I can use the 10x button but I don't think they are talking about the same 10x button...
Use that key on the bottom row to enter an exponent of ten when entering a number. Use x^10, the shifted function of the log key, to raise ten to a value.
How do I get my calculater to and and simplify completely 5xto the third power over 6xyto the second power divided by 10x over 3xy to the fourth power for variable y
The calculator does not have a CAS (Computer Algebra System). Therefore it cannot do symbolic algebra. It can only calculate numerical values.
You can enter algebraic expressions with symbols (X, variable), Y, A,B,C,D, and M but they will just be evaluated with the current values of A, B,C,D, Y, and M. If you use the SOLV program the unknown variable must be X.
The sum of the digits of a two-digit number is 12. the value of the number is five more than 10 times the the tens digit. find the number
The number is 75.
75 = (10*7) + 5
Let X = the 10's digit, then (12-X) = the one's digit.
Then 10X + (12 - X) = 10X + 5
Cancel both 10X on both sides.
12 - X = 5
12 - X + X - 5 = 5 + X - 5
7 = X = The 10's digit, therefore 12-X or 5 = the one's digit.
3helpful
How do you enter the problem 11x=10x-17 in the calculator to solve for x.
If you clean the expression you will find out that you need no calculator to get the solution.
11x=10x-17
11x -10x =10x -10x -17
1x=-17
The solution is x=-17.
Hope it helps.
7x-3+3x=-53 what is the value of 4x+9
7x-3 + 3x = -53
7x + 3x - 3 = -53
10x - 3 = -53
10x = -53 + 3
10x = -50
x = -5
Therefore 4x + 9 is equal to 4 times (-5) plus 9
-20 + 9 equals -11
How to calculate this equation
I don't know of a calculator that can do that for you, its transposition, you have to get x on its own to find its value which in this case is 0.9
what you do to one side you do the oposite to the other for eg
if 10x+2+45-56=0 then
10x+2+45=56 we moved -56 over the = to make it +56 then
10x+2=56-45 then
10x=56-45-2 which is the same as 10x=9 then
10x means 10 multiplied by x, so to move the 10 over it becomes division.
x=9/10
x=0.9
k24674
ADMIN Andrew
ADMIN Andrew
