Https://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?from_osc=&homeid=30969&idx=673861&modelcode=DMT800RHS/XAA&modelname=DMT800RHS
https://support-us.samsung.com/cyber/popup/iframe/pop_troubleshooting_fr.jsp?modelcode=DMT800RHS/XAA&idx=673821
https://www.youtube.com/watch?v=CIcQdApm6l0
Samsung Dishwasher LE leakage code FIX
SOURCE: dishwasher
The LE code indicates motor failure (or intermittent problem with motor). Based on what Ive read their support sucks, so sory to be bearer of bad news...
SOURCE: ERROR CODE "LE " ON LG DISWASHER
You should check for that the pump motor turn freely. You will have to remove the sump cover in the bottom of the dishwasher and manually turn the pump impeller. (note: screw holding the impeller on the motor shaft is a left hand thread) There may be an object there or at the cutting blade a bit lower down that is preventing the motor from turning. Motor should turn easily, smoothly, and quietly. There have been issues with magnets in the motor windings cracking, resulting in hard to turn or noisy motors. Also, models produced with serial numbers 501KW_____ to 702KW_____ may have wiring which has become embedded in the door insulation material, softening the wiring insulation, and causing a short to the motor. The fix for that is to replace the wiring harness and outer door liner with one with a different type of insulation. (not much fun to do)
SOURCE: Error code LE shown on
Hello JA12345,
Here is a link to the service manual for your dishwasher. Page 25 discusses the error code...
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Hope that helps you resolve your problem..
Regards,
Rick
SOURCE: What does the error code LE mean on my LG Dishwasher
MAin wash motor needs replacing
Affordable Appliance Repair
Lake Forest, CA 92630
Samsung Dishwasher Fault Codes | ||
4E | Water Inlet Valve | Clean and /or replace |
5E | Drain problem |
Check drain hoses Replace drain pump |
LE | Leak | Check for leaks |
Hi Jenny Carpenter, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? WHICH MODEL NUMBER?
DMT800RHS/XAA
I have the same Code Model Number Samsung DW60H5050FS
