SOURCE: Microwave turntable won't stop running
This is usually caused by either a bad door switch, but may instead be a loose door switch mount or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
SOURCE: everything works except the cooking part/no heating/turntable not turning, help!
PRELIMINARY REPLY
This is just a preliminary reply. We will need more information to help you.
So you're saying you can set the cooking time but when you press Start it won't start?
If this is the case, you probably have a bad door swithc or door switch mount.
Please reply back with more detail so we can help you.
you may have gotten a power surge and that can cause some funny things to happen, 1st is there power to the oven, 2nd if so there may be an internal fuse protector built in to the oven, check with the manual for anything of that sort listed. if not you may have to take it in and have it repaired by a pro. there is a lot of voltage in these ovens and unless you know what you are doing a person could get hurt
SOURCE: panasonic microwave no power or light
I must have suggested this 20 time today. if you open the casing you will find several fusees that the manufacturers don't want you to know about.
you have a 10 ampish large fuse that protects the power circuits ( transformer/magnatrons) smaller fuses for control circuits also might want to look atand reset the thermal cutouts. if it overheatedprior to failure
