SOURCE: Danby Dehumidifier DDR557HE has never dehumidified
either lacks coolant or compressor bad
Testimonial: "Thank you, I didn't even know a dehumidifier had coolant. "
SOURCE: Hi my Danby DDR4588EE Dehumidifier's
Hi! I'm assuming that the unit is plugged in and the outlet the unit is plugged into is working (if not, is there a tripped circuit breaker, in your home's circuit breaker panel?). Also, that you have turned ON The Master ON/OFF Switch and the Water Collection Bucket is installed properly and the Float Valve inside the bucket is in the Down position
If you answered NO to any of the above, turn the the Master ON/OFF Switch to OFF and unplug the unit, before checking those things first. Because, 9 times out of 10, one of thee above is the culprit.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
