Open following link for some Gardena resources, including manual and link to gardena site.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Gardena certainly has a glossy site, but I have been unsuccessful trying to contact the company.
Their products come with warranty and they show parts, but no hint where you can buy parts.I do not know how to fix your plastic timer valve, or if parts would actually repair the thing.
Maybe glue except I don't know a plastic glue that holds on outside of device under water pressure.
Plus I cannot see where it is leaking, and there is no description that tells me if valve was left outside and cracked with freezing water, or if the valve is 10 years old, or if exposed to hard water deposits or minerals in the water, or particulate has scratched moving parts, or high water pressure, or if wd-40 spray lubricant dissolved the o-ring, or if the valve cracked from an impact, or if exposure to sun/heat has made the plastic brittle.
From fixya standpoint, gardena is the most problematic watering device.
