Everything else working but the foot which moves garment is only going up and down.Reverse engages and there is a litlle movement backwards.
Viking Husqvarna 150 180 190 Sewing Machine Instruction Manual Pdf
If it's an older mechanical machine, very possible it needs a thorough oiling and cleaning.
Wheel on right side that controls the needle up and down is very tight...
SOURCE: 99 FORD TAURUS driver SEAT RAIL TRACK
U will need to replace the power seat transmission, the gears are most likely stripped out, not uncommon, this part is $800 so i would suggest u try to locate a used one.
SOURCE: 1996 Mercedes SL Power seat problem
hi,seat motor are in maximum length,try to seat,then apply force backward also the switch in backward mode.
SOURCE: Power drivers seat does not move forward and backward
if thare is a clicking sound heard then the fuse is not blown so this means ether the seat motor or transmission has gone bad and you half to replace the hole seat track, cause i dont think servisable parts are available for this vehicle
SOURCE: Drivers electic seat will not adjust
I just had the same problem. When the seat is powered all the forward, one of the worm drives reached the end of its travel and jammed against the threaded block that it passes through. To fix this the seat has to be unbolted and tipped back. There are four tiny 6mm bolts that hold the motor plate in. Remove these and the motor will come out. The worm drive is bolted in at one end and has a set pin at the other. Remove the worm drive and use a couple of vice grips or equivalent to loosen the threaded block from the worm drive.
