Have one wet jet, almost new, with new batteries and can't get it to respond. Another that I was able to unclog one opening to spray but other has no spray at all.
SOURCE: THANKS GEJANDSONS. I soaked carb over night,
Did you just soak the carb or did you disassemble and soak?
If you didn't it might be a good idea because it sound like a stuck float. I would pull the bowl off. If you have done this before then you know .If not then make sure you have a clean are to take this apart. Take your time with separating the bowl and main carb body because the gasket can tear easily. Be careful with the mechanism near the float hinge. There is a small clip that seems to vanish into thin air if you take your eyes off it. Make sure it's clean and reassemble. Now before you put the bowl back on make sure the float moves freely. Reattach it and give it another try. You might want to consider resetting the high and low idle screws also. Start by turning them all the way in then backing them out 1 1\4 turns.
Hope this helps.
If you are still having trouble after trying this let me know.
SOURCE: I have a SOLO 461
if it is a diaphram style replace diaphram if it is a piston style replace piston how to's are easy on both just take ur time and pay attention to removal process
