SOURCE: Chopsaw
hi hope to help you!
firstly see if the blade is going the correct way if so
you should replace the spindle shaft and also fit a now bolt only use makita parts though!!
the problem is the thread in the spindle and bolt are worn.
Hope that helps. Sean.
SOURCE: macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
I am sorry but fixya.com doesn't sell parts of any kind.
