SOURCE: saw will not run
I had the same problem several months ago with a craftsman (shut down during a long rip), and the reset switch had tripped but did not actually pop out. I tested everything in the line between the power supply and the motor, and found out that the reset switch was not conducting. I was able to reset it manually before re-installing it into the saw, and it's been fine ever since. I'd test that before you start pulling the motor out, it would be a much easier fix if the switch was just sticking.
SOURCE: Table Saw Craftsman 113.299410 Manual
Here ya go...
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0060111.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: need manual for bosch 4000 table saw
You can get manual at link below.
owners manual.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00160v-1.pdf
Parts diagram.
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00442v-1.pdf
Good Luck
SOURCE: replacement motor for table saw
I would suggest taking the motor to a Grainger or equivelant type of business and they can probably match it up with a Dayton motor that would replace this one. They will need all the information off the data tag to match it up.
SOURCE: Manual Craftman professional router table model
I had the same problem as far as the manual is concerned. I emailed Bosch. They responded and told me this is actually a Vermont American router table, and said they would put a copy of the manual in the mail to me. I haven't received it yet.
