Garden Logo
T
Timothy F Brush Posted on May 21, 2018
Finding a replacement seal for mastercraft water pump model 312242
Graham Moss
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 2 Answers
  • Posted on Oct 22, 2019
Graham Moss
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
1174
Points
Above answer is talking about an automotive water pump. This is a jet pump for home cottage water supply. Canadian Tire do not stock parts for any of their Mastercraft pumps. I found that out the hard way! For a seal, you may be able to find a generic one. A company that repairs other makes of domestic water pumps may have one that will fit.
1 Related Answer
Bill Boyd
  • 53816 Answers
  • Posted on Jan 09, 2014
SOURCE: Replacing water pump & timing belt on 2001 Dodge Stratus R/T. Easy to replace front main seal, too?
oil seal failure is the main killer of rubber timing belts . Oil can come from the crankshaft seal --the cam shaft seal/s and the hydraulic belt adjuster.. So if you have the front off and am replacing the timing belt then it is fools economy not to replace the seals and any idler pulleys at the same time.
I have a Mastercraft jet pump Model #561471 complete pump rebuild kit needed. Where do I find one.
google Mastercraft jet pump Model #561471 parts
If it as described I would put new pump in. If you chose rebuild it A new is is $250 on eBay.
Jun 26, 2023 • Pool & Spa
Mastercraft makes sells a lot of pumps. You might want to post with the model number etc. You can also go on line and probably get the manual that will show how it is done.
Apr 30, 2014 • Plumbing
1helpful
Mastercraft jet pump how do I take it apart for new bearing and seals
There are a lot of different pumps, look in the manual or go on line and get it. If you need more help I would suggest adding the model number etc to your post.
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
I need to find a replacement 18.0 volt battery charger for my cordless drill model x8296 ?
That model number is for Mastercraft drill. I would search Mastercraft cordless on Ebay or Craigslist to try to find one.
Mar 06, 2011 • Garden
2helpful
3answers
Milky oil on my wr450f 2004
your water pump seal and oil seal have failed on the water pump shaft. Replace both seals noting which way the seals face. replace the water pump shaft if it is scored. Chaz- Moto DC
Top Mastercraft Garden Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Mastercraft Garden Expert? Answer questions, earn points and help others
