For omit 12 dimension
SOURCE: Texas Instruments TI-30X IIS Calculator '+/-' sign
it is just a (-) symbol and it is beside the decimal point (.) button
SOURCE: I just bought a texas instruments TI-30X IIS
if you want to use your calc for this you would have to put it in as the operations to change the mixed to improper fraction i.e. input exactly as "((8*3)+6)*((3*7)+1)=" remember? take denominator times whole number plus numerator and put over denominator to convert from mixed to improper... hope this helps
SOURCE: I am trying to find
There is a quick guide here which should help http://education.ti.com/downloads/guidebooks/scientific/30xii/30xiiqrg-eng.pdf
So you press 2nd Function , select 1-Var or 2-Var (for paired datat) then enter your data pressing down arrow after each and Enter to finish then press STAT / VAR to see the various variables
Please give me a thumbs up if this helped
SOURCE: how do i go from dms to decimal degrees with my ti-30x IIs
Press the key that is marked with a small circle, an apostrophe, and a double quotation mark. That is the DMS key. You can use it to convert from Decimal degress to DMS and back.
