Question about JVC Video Cameras
I have a jvc gz680sek camcorder which i was using today but suddenly it now shuts down straight after start up is this a bettery problem. I also cant see a light identifying charging.
6ya staff
SOURCE:
hardrocko
Kim Yearick
  • 1476 Answers
SOURCE: Sony Handycam DCR-HC30 2004 model
Your unit is a 2004 model. If it has never been used since then the battery is probably no good and will need replaced. Batteries discharge 20% on a monthly basis just sitting on the shelf so yours went dead a long time ago. Then if they are left in that state (dead) they sulfate which means that sulfur oxides transfer to the plates and form an insulating surface. At that point all the charging in the world is not going to bring it back. All you can do is get another one. They are available at most stores which sell electronics. Get a new battery and charge it per the instructions and try using it again. This should solve your problem. Good luck.
Posted on Jul 20, 2006
Anonymous
  • 30 Answers
SOURCE: jvc digital video camcorder gr-d20ek no power
wipe the contacts with after shave solution or isoprophyle alcohol, this may do some magic
Posted on Aug 15, 2007
Anonymous
  • 579 Answers
SOURCE: Standard TV-Auto shut down
TV's have a circuit that monitors the high voltage and shuts down the set if it senses something amiss.
Figure on replacing the flyback transformer.
However, my experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board from an outfit like PTS Electronics at ptscorp.com.
Hope ya fix it!
Posted on Feb 04, 2008
Anonymous
  • 72 Answers
SOURCE: Nokia 6500slide screen fades to black and white then offs
Its a Virus Problem CommWarrior.
Format Ur Mobile.
Posted on Jan 09, 2009
Anonymous
SOURCE: Reciever Shutting Down
I replaced R916 with a 10 ohm wire wound resister and that fixed the problem on the unit I have. That resister is in serise with R 915 so they should be close in value. Both were marked 8 ohms but tested about 11 ohms on R915 and the bad one tested very high (over 1 meg) so I replaced it. When I first put it back together it didn't work but I noticed that the ground screw at EP901 was not retighted so be sure that all ground screws are tight and all conections are redone before testing with the power cord.
Good Luck,
Thomas
Posted on Aug 06, 2009
Have been using my JVC Camcorder GR-DVL520EA for past 3 days including earlier today recording. I have just started rewinding the tape back to start to review it and it has put a message up on screen...
This is usually caused by a failed component in the moisture detection circuitry within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Sep 20, 2010 | JVC Cybercam GR-DVL520 Mini DV Digital...
How do i fix my friends camcord JVC plz help i have to return it today and ive lost all his videos the videos i can replace because i have them on my computer its the camcord i cant i live in New Zealand...
Connect the camcorder to the computer with the data cable for the specific camcorder.
Then you can find the computer detects the camera .
You can see the camera partition in the my computer option
Then click the camera partition and paste the videos in the camera's hard disk .
Sep 15, 2010 | JVC 20GB Everio GSeries HDD Digital...
Camera worked great until last month!
OK, it is known problem of CCD Imager chip failure in JVC GR-D33 camcorder and ccd imager will be replaced to get live view for recording, lens cap message will disappear as well.
JVC will repair your camcorder free of cost for same problem, click JVC CCD Imager Support for details.
Thanks.
Sep 18, 2009 | JVC GR-D370 Mini DV Digital Camcorder
JVC GY-HD110U
discharge your batt. fully. charge your batt. on 3phase current. dont remove in middle, give time for your batt. to charge fully
ues JVC original batt.
Jun 18, 2009 | JVC GY-HD110U Camcorder
I NEED DRIVERS FOR JVC GR-D93
i need drivers for jvc gr-d93 for windows xp
Nov 14, 2008 | JVC Cybercam GR-D93 Mini DV Digital...
Safeguard mode error 06
Defective mechanism,
a stucked mechanism is
present. camcorders are
smart. it can detect error
and shut down itself for
safety. earlier models
domino the defect if
the user is not quick
enough to react when
something goes wrong with
the camera. You need
professional service to
fix it.
Dec 12, 2007 | JVC GR-D240 Mini DV Digital Camcorder
Good Luck,
Thomas
Dec 13, 2006 | JVC RX-8010V Receiver
Video Cameras Logo
144 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
