Well, without a brand and year, it will be hard to figure out exactly. Here are some basics.
First thing, peg the tent down. (At leat the corners)
Next, locate the two longest poles. These are usually fit through a sleeve in the roof of the tent and attached in the corners via pegs or inserted into a pin. Put one corner in, then go to the other side and slide/bend the pole until it fits into the corner. Let it flop on the ground. Do the same for the other corner and the tent should be standing.
Next, if there are other poles, they could be for the front entrance or to support the rain guard. Look for peg holes or pins to place the poles into and that should give you an idea. (Also look up your model on the internet to give you an idea how it looks.)
Depending on where you are camping, you may not need the rain cover. It goes over the top and probably bungies into the peg holes.
Hopefully this will get you started. good luck. Alley
Remove the tent and poles from the packaging. Select an indoor area with a high ceiling or an outdoor area without overhead obstacles. The poles are not excessively long but they will be difficult to assemble without space.
Lay the Princess tent with the floor on the ground. Pull on each corner to tighten the floor. Assemble the two tent poles by inserting the male sections into the metal ferrules.
Slide one pole through each of the diagonal sleeves. Place the end of each pole in the fabric pockets on the corners. This will flex the poles and raise the tent body.
Place the fabric roof on top of the tent. Attach the hooks on each corner of the roof to the loops on the top of the pole sleeves. The roof fabric will stretch tight and cover the ventilation gap in the tent ceiling.
