Question about Psi Air Tools & Compressors
My Super SilentAir Compressor not holding pressure.
My Super SilentAir Compressor starts builds pressure to 90 psi, I start using it, it drops to 60 psi...in order to get it back up to 90 I have to remove the hose then re-attach the hose it builds back to 90 psi and the same thing happens again..over and over..
6ya staff
SOURCE:
Anonymous
  • 266 Answers
SOURCE: air compressor can't start (hums) under pressure
maybe high pressure vavle is bad
Posted on Jun 20, 2009
River bottom
  • 174 Answers
SOURCE: Air compressor motor stalls under pressure
this sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Posted on Jun 22, 2009
Anonymous
SOURCE: Insufficient Pressure From Pump
Take the strainer at the end of the hose on the tank off. Throughly clean it. I used an old tooth brush, then ran hot water through it several times. Also drained the tank and flushed it out 3-4 times with fresh water, then ran fresh water through the pump for several minutes
Hope this helps
Posted on Aug 09, 2009
laseramp
Daniel Dollive
  • 314 Answers
SOURCE: 60 gal farm hand air compressor starts, builds up
bad regulator or safety valve will often cause this. when pressurizing up, a small switch is pressed by the air in the tank pushing on a small piston, this is a safety feature and may need to be replaced. might wanna get it serviced. the unloaded valve will open when the air in the tank reach the set amount. http://www.ag.ndsu.edu/pubs/ageng/machine/ae73-07.gif
Posted on Dec 21, 2009
Repair Ahjoshe
  • 885 Answers
SOURCE: My four-year old PC pancake compressor starts fine
First take off the head on the air pump and check the reed valves on the valve plate. If they got hot and warped or cracked they'll work to a point then no more pressure can be built up. Next check the pistion ring and cylinder wall. If either is damaged you'll only get so much pressure build-up then it will leak past the piston.
Posted on Mar 07, 2011
Testimonial: "Quick response and the solution makes sense now that I've seen a parts diagram"
Air compressor want run why?
First thing... that model of air compressor was recalled in 2011.
https://www.accessaap.com/wcsstore/CVWEB/Attachment/staticbusinesscontent/image/0415_Strike_Force_Recall.pdf
If that is of no concern to you... then look in the manual about how to adjust the cut-in pressure. The cut-in pressure is what controls when the compressor portion turns back on. There is often a set screw that controls this.
Nov 11, 2017 | HP Air Tools & Compressors
Air compressor will not restart after it builds pressure and pressure drops to 80 psi
Make sure the power cord is plugged into an adequate extension cord if one must be used. Never less than 12 gauge wire.
The start/run capacitor may need to be replaced.. If there are any ball check type valves, make sure they are not worn or sticking. they would be on the output of the compressor head itself.
Dec 13, 2011 | Hitachi EC12 Portable Electric 2hp Air...
My four-year old PC pancake compressor starts fine but only builds up 60 psi no matter how I adjust the pressure regulator. The compressor motor runs continuously. I checked for air leaks and can't find...
Mar 07, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I replaced the compressor on my refrigerator. There were no tags as to how much freon the system takes. So I added enough to bring the low side to 72 psi w/ a cabinet temp of 70 degrees. The high side...
**** boy. 72 psi on the low side? It ain't an air conditioner. The low side should be never over 5 PSI. The whole system holds only arounf 4 ounces. What were ya thankin? LOL WOW you will be lucky if the reed valves ain't blown in the new compressor. Go ahead and evacuate the system. Pull that ****** down to as close to negative 30 as you can and then shut her down. Just crack open the freon a hair and let it SLOWL:Y build to no more than 5PSI on the low side.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2011 | Refrigerators
Oil pressure drops to zero when engine starts then goes to 60,while driving after warm,pressure drops down 4.3 V6 vortec engine
The 4.3 engine should have 20 to 30 psi at idle cold and around 50 to 60 psi running down the road. Has this engine had regular oil changes? If not the problem could be sludge build up. The oil pressure sending unit could be the problem. If in question about the sending unit install a mechanical gauge and watch the pressure.
Jan 02, 2011 | 1999 GMC Jimmy
Pressure switch adjustment problem...
I think I follow you... the adjuster over the large screw is used to set your tank pressure but also sets the cut-in/cut-off pressure. You have another regulator to control the pressure to and thru your hose but that doesn't insure that you won't exhaust the tanks supply and use more air than your pump can produce. It doesn't matter what pressure you set it at if your pump can't produce enough cubic feet per minute of air to keep up with your output. If your air use/output is within the pumps output, your idea will work just fine and you can set the hose regulator just below the cut-in pressure but Remember, even a little airbrush uses a lot of compressed air but sanders, grinders, sprayers and impacts use a Ton so don't try this without having somebody monitor the compressor periodically while you try it. It all depends on your air demand.
Apr 27, 2017 | Campbell Hausfeld G5396 7 Hp 60 Gallon...
I have a model FP209501 Air Compressor 2 Gallon,
2 gallons is small to begin with u need to buy an in line pressure adjuster/regulator their a few bucks and can be attached to the paint gun or line and will keep the pressure at ur adjustment the regulator on the tank sets the tank pressure at 50 so when u us it will let it drop down to about 45 than start up to build the pressure up to 50 than shuts off than repeats it self the inline keeps pressure steady even if tanks are at 200 psi
Jan 18, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
My hitachi EC12 compressor starts up and fills the two tanks. When I connect my hose, the pressure in one tank drops to zero, then goes back up to about 60 psi, then very slowly builds back up to max...
how do you know one tank drops to zero unless you have a pressure gauge on both tanks sounds unlikely unless you are looking at the gauge on the pressure regulator
Nov 18, 2009 | Hitachi EC12 Portable Electric 2hp Air...
Jun 18, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
24 people viewed this question
Top Psi Air Tools & Compressors Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Psi Air Tool and Compressor Expert? Answer questions, earn points and help others
