SOURCE: Boiling
Purchased at Canadian Tire mid December 07.....great sale....still more than I expected to spend on a kettle. EE and nothing.....same as previous customer comments.
SOURCE: Can I buy replacement batteries for Shark Cordless Sweeper
I need a replacement battery for my Shark Stick sweeper model V1911 N. Can't find it on their web site. I guess it is old. Murnieruth
SOURCE: I have a yardworks 50"
What you really need is a manual and diagrams I have found you a link that will provide both please go to the website below and choose your model.
http://www.m-and-d.com/MTD_Parts.html
Below is the MTD support site, so if you need you can contact them direct.
http://www.mtdcanada.com/model-search.asp
SOURCE: changed motor on Yardworks 14.5
This is quite straight forward the new motor was not properly fitted into the unit. Therefore the clutch is not disengaging the gears to allow for other gears to enter. If you had an expert fix the new motor for you then send it back to be fitted properly as the list of things that could have been done wrongly in the process of fixing the motor could extend a mile when listed. And if on the other hand the motor was fixed by you then get an expert take a look at it.
Hope this support has been helpful?
SOURCE: I have just bought the
Delayed Watering
You can delay the first watering cycle of each watering zone by up to 12 hours by using the small button at the bottom middle of each zone area. Press the delay button 1 time for each hour you wish to delay the first start time. The "Low Battery" light will illuminate when you press the button. The maximum delay is 12 hours.
For example, if you are programming at 4:00 in the afternoon and you want your timer to water every 12 hours, but you want the first watering of the day to start at 6:00 a.m., press the Delay button two times. Without the delay, the first cycle would have occurred 12 hours after the timer is programmed (4:00 a.m.). The delay feature changes that to 6:00 a.m. The timer will then water every 12 hours after that.
