Switch of the light button,remove the damaged bulb and replace with the new work.End light the light buttonSwitch of the light button,remove the damaged bulb and replace with the new work.End light the light button
You can't post conmments that contain an email address.
What is wrong with these parts? The speedo cable should be changed for a new one if broken. Is the bulb in the rear light OK? If so, is there any electricity in the socket? If not, any fuse blown? If not, you have to trace the cable to se if any connection is loose.
hi...yes the high beam & pass light use the high beam element in the bulb....no this sounds a bit daft/obvious....but have you changed/check#ed the bulb...the low beam element hasnt blown...has it???...for the price of a bulb i would change this...hope this helps
Remove screws on rear of rear light housing, both left & right. Pull bulb housing to rear until it's clear of holders. Turn bulb holder counter-clockwise to remove it from the bulb housing. Press bulb into its socket & turn it counter-clockwise to remove.
