Hello to all I have a tv hannspree hsg1113 with universal remote control this is fine just think I have fashions and does not make me tune the channels, - how do you remove the hotel mode ?? how do I enter the internal menu? thank you to all I have a tv hannspree hsg1113 with universal remote this is fine I think it has been a hotel and does not make me tune the channels, - how do you remove the hotel mode ?? how do I enter the internal menu?
SOURCE: Philips tv
you probably need a hotel master remote, i.e. the philips rc2573gr:
http://salestores.com/philipsr.html
SOURCE: gemini universal tv remote
Hi, I have the same remote (CL033 one) and I found these instructions http://klkl.co.uk/?p=13 and they worked great for me.
SOURCE: TV Tuning on ALBA TV with DVD player
you start with tv,dvd mode to your remote control when you have alread make sure your in tuner you hit menu mode and show you the instruction select arrow shows _ + try it.
SOURCE: RCA T19064 - HOW TO GET TO MENU
i have the same set i used a rca universal remote rcr311w i think its the oem one i bought two of them at walmart i don,t know if they still carry them
SOURCE: RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
