Please help.
Try to delete some recorded calls, some cordless phone have only limited memory/storage calls and it will block incoming
Testimonial: "Hey Jojo Thanks for the reply, i've cleared my records. I've noticed that there is no signal on the phone network display pole. Do you have any knowledge of how to factory set this Bell phone or any other?"
SOURCE: reprograming my voice message for incoming calls
hi
you can get a downloaded manual from here
http://theusermanualsite.com/manuals/mfg/panasonic/panasonic_kx_tg2257_kxtg2257.html
hope it helps
riz.
SOURCE: no ringer for incoming call
I have seen this issue before and panasonic knows about it. I would contact them directly.
SOURCE: Can not pick up line on incoming calls from one extension only
That's what happens when you plug in the system and don't program it. You need to review ICD groups.
By default, the phone connected to the first extension is the master phone and the only phone that rings.
Carl
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: Telstra V580a cordless phone not working.
Try disconnecting all power to the base stations and the batteries in the handsets for a few minutes.After reconnecting power it may take a few minutes for the units to reconnect.
Good Luck
Doc
