SOURCE: Batteries are not recharging.
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
