The alarm lamp lights flashes orange with error E15
Here is a link to the troubleshootinh guide http://ugp01.c-ij.com/ij/webmanual/Manual/W/MG3500%20series/EN/CNT/CNT_Myprinter_Trouble.html
Follow the link Clear Canon Pixma E04 E05 E14 E15 1682 and 1684 Error Messages
Imaging drum is empty or missing (Error 40204)
Light pattern
Description
The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly.
Action
Imaging drum e-label reader is faulty (Error 10004)
Light pattern
Description
The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly.
Action
SOURCE: triangle on front constantly on orange. wont scan nore print
Replace or refill the VO51 in cartridge, it's out of ink.
SOURCE: Cannon PIXMA Service Error
Hi You can Try 2 things.
Have a go
There is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I have a paper jam on my pixma mg 3150 printer any help
Did you tried the Canon solutions?
Try HERE or HERE
Good luck
