Could be the magnetron, I suppose..
Why is my microwave not heating up?
This high voltage powers the magnetron to heat the food. If the diode burns out, the magnetron won't receive enough voltage to operate, preventing the microwave from heating. When the diode fails, it is often visibly burned out. Inspect the diode and if the diode is burned out, replace it.
Test the Magnetron:
http://www.microtechfactoryservice.com/mag_test.html
SOURCE: Our cuisinart cmw-100 still has the power sources
Bad door switch, usually the top one. The switch costs < $2.00.
SOURCE: I need to find the
Hello &
Welcome to FixYa You can buy
the motor from here or from here. Please get back to me if you have any other
questions. Kevin
SOURCE: microwave is loud
It is normal to have a moderate sound, but if extremely loud it indicates trouble with the magnetron, should be returned for a replacement.
SOURCE: Cuisinart microwave CMW-100. How do I change the lightbulb?
You need to remove the cover from the oven. Pull the plug first! Remove the Philips Screws. There are two special screws that are meant to prevent your proceeding further. No standard driver will fit these screws. You can remove them with small pliers gripping the outer edge of the screw and turning counter clockwise. If you are not familiar with capacitors, get somebody who is familiar. The light socket snaps in. Unsnap it. The lamp is taped to the socket with cellophane tape. I have never removed the lamp nor do I know the number. Do not plug in the oven with out the cover!!!!!
Here
is a tip that will help you to figure out what is wrong with your
Microwave Oven....
Basic Microwave
Oven
Troubleshooting Tips
heatman101
