Hi All,
I have a Abit Kn9 sli board and have ahd problems with it overheating , i can be in the setup and in pc health tab and watch the temp rise and rise and in the end the system will shut down ? i brought another standard heatsink and fan but nothing changed so i went out and bought a Akasa evo 120 heatsink and fan but when i fit the new heatsink the system turns on for a few seconds then shuts down without putting anything on the screen ? if i refit the old one it works but just overheats ? i have made sure the new heatsink is fitted properly and is tight to the board ? Im running out of ideas now ?
Any help would be great
Thanks
Paul
The problem could be a failed electronic component, and no cooling remedy will solve the problem. When some components fail, they result in high heat conditions.
Posted on Aug 06, 2009
Jun 29, 2012 | Abit KN9-SLI Motherboard
Sep 01, 2007 | Abit KN9-SLI Motherboard
Mar 23, 2011 | Abit KN9 SLi Motherboard
Dec 02, 2010 | Abit KN9-SLI Motherboard
Jun 20, 2010 | Abit KN9-SLI Motherboard
Jan 14, 2010 | Abit KN9 SLi Motherboard
Oct 14, 2009 | Abit KN9 Ultra Motherboard
Oct 12, 2009 | Abit KN9-SLI Motherboard
Jul 30, 2009 | Abit KN9-SLI Motherboard
Jul 08, 2009 | Abit KN9 Motherboard
204 people viewed this question
Hi Hank its shutting down at 90 degrees which is what its set to in the bios , im using the thermal paste that came with the akasa heatsink im not sure if this is good or bad stuff? i seemed to have sorted it a bit it dosent get hot now at idle but under load it goes up and up ?? im using speedfan to monitor it as soon as the cpu is put to work the temp goes up ? also the core temp seems hot all the time idle or load ?i have orderd some artic silver compound now but think it might just be a bad cpu?
Any help will be great
thanks
Paul
Hi ya Hank,
I think its celcius i have ran sppedfan on my laptop and it measuers in celcius i think ?? im guessing thats quite hot then? the cpu is a amd am2 3000+ its running stock numbers its not overclocked so not sure why its running so hot? i have orderd some artic silver today so i will try that . Do you have any ideas why the new heat hink wont work when its connected to the cpu?
Thanks again
Paul
Hi Hank,
I have 3 fans fitted in the case 2 80mm at the front and a 120mm at the rear all the bios settings e.g fsb and voltage are standard ill try the fan idea and see what happens the artic silver should be here tommorow so that might do some good .
Thanks for all the help/advice
Paul
Hey Paul, Do you have adequate cooling fans in the case and good air flow? Are your voltage and fsb settings in bios correct? Seems you know what you are doing, but I'm just "pulling straws".. Check bios settings. Take side panel off computer and put an electric fan so it blows air across your mobo,...see what happens????/ Hank
Hi Paul' When you say 90 degrees, I hope you mean 90 degrees fahrenheit and not celsius..please confirm that it is 90F. Also, what processor are you using? Hank
Hi, Please let us know at what temperature your system shuts down at. Also, let us know what thermal compound you are using. Thank, Hank
