We have never had any problems with our oven (EVER!) :-) (yes it is an oldy but goody - purchased in 1991)
Tonite after using it earlier in the evening with no problem we turned it on to preheat and after about 30 seconds to a 1 minute, the Display window went to F3 and the oven started to beep.
Can you tell me what this means. I can't find any information in the Owners Manual about error codes
Thank you so much!
I truly appreciate your response and have ordered a part based upon your response. Assuming the part works you can be sure that I will reply with a very postive Fixya!
(P.S. I tried calling Sears to get some validation from them - what a waste of time!!!! Very Sad...)
I should know in the next couple of days!
Thank you for what you do!
If I don't get back to you please send a reminder and I will be glad to.
JEFF
Success!! Thank you Chris72!!
You get a Triple Fixya from me!!!
Have a wonderful holiday season!
JEFF
Thanks for advice - it sounds like we have same problem - have purchased a replacement oven sensor - challenge is to put it in - can it be replaced from inside the oven or do we have to pull the stove out ? - wire attached to sensor seems about 6 inches long.
Thankyou - KEITH
GE built in double oven, 1996, model JTP27, oven preheats,beeps when gets to set temperature, few minutes later get an F3 alarm. Sounds like the temp. sensor, just wondering if you have to pull the oven out or is it just behind the touch panel??? thanks, kelley
[email protected]
i get a f3 error code on my oven when i try to get it to preheat
F2/F3 codes in display
This weekend I was warming some items in our oven (Kenmore 911-4088816), when it suddenly starting beeping loudly and had F2 and/or F3 in the display.
Is this the Clock Control ?
we had a power outage and surge in some areas of our home. now the kenmore oven is asking up. Stove top works great, but when I try to pre-heat oven it beeps and flashes F3.
Julie
We are cleaning our Kenmore builtin oven/microwave and an F2 alarm is now sounding. Any ideas?
I was cooking food in my oven and I heard it beep and F3 code came up where the clock is. My oven wouldn't shut off. We had to disconnect the oven to shut it off.
we just replaced our sensor because repair said F3 meant sensor was bad. It still shows F3 and beeps.
