Depends on your model. The smaller pour over units are easy as you prep your funnel with coffee as normal and get a full pot of hot water (just brew the water through the brew head and funnel to fill the pot.) If you have another pot or carafe, air pump pot. Then hold the coffee filled funnel (with coffee filter) over the empty pot and slowly pour the hot water over the coffee grounds. Go slow as you don't want to burn your other hand nor get grounds into the pot if you over fill the filter.
* If this is a 1-1/2 gallon brewer then the missing shower head won't mater that much as most of the 'flavor' is extracted in the first 1/2 gallon with the rest just filling the urn. If you do find the coffee to be weak then perform 3 separate 1/2 gallon brews to allow the grounds to fully soak and extract. Again, you can still do it manually as described above but it does get messy and very slow. (I've done this just to get something out to the customer. Well until I could get the repaired brewer up and running.)
* Most of the Bunn decanter brewers use a quarter size screw on spray head. No real substitute, though you could try a stiff sheet of aluminum foil to cover the coffee grounds in the funnel and poke holes into it. Though more than likely one of the waiters will dump it on the next brew.
* On one occasion (during lunch rush) I had to wait on a repaired urn to heat up but the waiter's needed coffee now! I took a pour over small brewer and made a pot with 1/2 gallon strength coffee and poured it into a larger urn then brewed more 'partial' batches till it was full. Hey, got to do what needed to get it out.
* You should always check with your coffee vendor as spray heads are very common parts and available at your local restaurant supply. There are other brands that use the same parts too like bloomfield. Ask around as this is a fairly cheap part.
Aloha, ukeboy57
SOURCE: my bunn is too slow
Use the de-liming spring to clean the copper tube behind the spray head. Pour several pots of clear white vinegar through the unit to further remove lime and scale from the interior of your coffee maker. My Bunn is 24 years old, and the only replacement parts I've ever required are new carafes and the 4041 silicone washer repair kit.
SOURCE: my bunn coffee maker leaks
You need to replace the washer kit inside the top of the maker. Remove the 3 screws that fasten the top and lift it off. You will see the rocker leaver that allows the water to flow into the tank. At the point where the rocker stops the water there is a series of washers that degrade from the heat over time and allows the leak. The washers are very easy to replace. The problem is finding the washer kit. I found it at: www.buyitnow64.com for $3.95 plus shipping (FedEx is only $9.98). I bought 2 (one for backup) kits.The original washers lasted almost 6 years. I had repaired this problem before with a washer from my shop but it broke down rather quickly from the direct heat from the tank. This washer kit is a Bunn washer kit that is supposed to fit all Bunn machines both residential and commercial.
Hope this helps. It took me 2 hours on line to find the washers!
SOURCE: Water supply for Bunn coffee maker
open the cover on the brewer- depending on your model, it could be the front or the back cover. look for a brew timer dial. turn this up slowly, running a brew each time to see if you now have a full pot
SOURCE: Bunn coffee maker leaks water
There are 3 seals in your unit that could cause your problem. there is a silicon seal right under the pour-in tray, and two on the top of the tank. one of those is for the thermostat, the other is for the sprayhead tube. any of these could leak, causing water to come out the bottom of the brewer. One other thing that can cause this is a scale buildup between the pour-in tray and the tank.
SOURCE: I have a bunn coffee maker the NHBX is the # it is
Please give Customer Service a call with the model and date code. If the machine is 3 years old or less, it will be replaced with a new machine. If it is older than 3 years, it can be exchanged for a reduced price.
