SOURCE: "file protect"
Thanks, but the problem is not worth paying for a solution of. I was hoping for a freebie but......
SOURCE: White Sreen
unfortunately it would appear to be a CCD or main board failure.
If the camera is out of warranty (as this should be covered) my best suggestion is to pick up one off ebay with a broken screen and put your screen in it, broken screens are common on these cameras so they go quite cheaply, far cheaper than kodak would charge for repair and the swap is easy.
There are several searchs to try "parts v1003" "spares v1003" "Faulty v1003" "repair v1003"
Best of luck
SOURCE: my Coolplix L18 wont let me do nothing
Hi
Take the memory card out of the camera.
You will see a small switch on the card (it is the lock switch)
Slide it to the opposite side and there you go!
It's easy to accidentally lock your card without even knowing it.
lol my mom just had this exact same problem and it was driving her crazy (she too didn't realize the card had a physical lock switch)
Have funn,
Bye
SOURCE: Finepix J20 Digital Camera- says:PROTECTED CARD!
My bet is that the little switch on the SD card is in the "lock" position. Switch it off and try again...
Testimonial: "Hi I left the comment about the Fine Pix Fuji J20 camera, and I am not sure where the sd switch is on the camera. please if you can let me know.Thanks"
SOURCE: My card keeps saying that it is write protected
There is a little slide switch on the left side with the connector away from you and connector on the bottom. Slide it towards the connector or away from the connector.
This may be your problem or the switch may even be damaged.
