NO OS told at ALL, XP to W11 what is the goal here?
h57 is good chip set, w10 runs it. series 5 it is called
google the manual yet (w10 support for the intel chips here only)
not sound.
why did you say Intel???? a blue mobo from intel?
Acer????green board and Acer white ink clear as day? ASPIRE?
acer does not publish pins, nor does any OEM PC.
asus and asroc, mSI and gigabytes do DIY mobo have real manuals and OEM do not,
the trouble is not telling 2 things
lost the PC did you, OEM case and all that gone?
bought a rouge mobo from ebay , and is not DIY but pulls from ACer PC and not told by the seller, 99% of the time they lie by omission.
where did you get the mobo, and was it just a mobo bought.?????
history mattes
for sure acer mobo, that has no parts lists at all .
best way i to look up mobo numbers is google
to see sellers that not lie. (sells mobo and no manual and for sure no pinouts and driver none)
1st hit
Acer Veriton M490G M498G M680G S680G Q57H-AM Motherboard H57H-AM + I/O SHIELD
Vertiton means desktop. and acer.com has manuals and driver there for
all my ANSWER ARE USA, what you get in your country if not 1 clue. nor want to know 50 contries, laws. on such.
acer.com
support
desktop
veritron
M series.
490G
bingo
https://www.acer.com/ac/en/US/content/support-product/2106?b=1
windows 7 max 32 or 64bit. no w8 no w10 no w11 , period
and ever.
2010 audio driver is there, and must be loaded for sound to work.
why not just use rear of PC spackers out green jack
and forget lost internal or front speaker jacks
no PC told not told if all acer cables were lost.
no clues at all but mobo raw number.
hard nut to crack, and did it.
2009 made
load the driver to w10 using w7 to w10 compatibility mode
and toss a coin, ms tells how, endless.
acer only tells how to plug-in their PC cables. only
no detail at all, never buy acer for that reason alone
only a lame basic manual,. there,
SOURCE: FRON PANEL
You can download the manual(zipped PDF file) for your motherboard here:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=M2N-MX%20SE
you can find the pin details on page 1-29
SOURCE: SL-75KAV
Here ya go http://www.motherboards.org/files/manuals/118/75kav.pdf
This has all the pictures you will need to reconnect everything. If this helps be sure to rate my help.
SOURCE: MOTHERBOARD AUDIO PIN CONNECTIONS
The pins are pretty much universal, I'm 90% certan that the other one of these is correct for you.
SOURCE: Intel DP35DP Motherboard spdif connection
Go here for a manual, which may help you.
http://support.intel.com/support/motherboards/desktop/DP35DP/DP_manual.htm
SOURCE: I need a diagram that shows the pinout for front panel audio.
Could you be less specific as to what motherboard and front-panel, and why you couldn't download the manual from the maker if you pitched it out?
Then, to be sure, get a DVM with small probes, set it on continuity, and confirm the pinout.
