The machine is about 13.5 years old. The number on the manual is 4619 702 20091
SOURCE: Kenmore Elite HE3 washer lights light but wash won't start
Sometimes I just have to unplug the machine, wait a few seconds and plug it back in and it works. I guess it resets itself or something.
SOURCE: Need part number for rubber boot on my kenmore elite HE3t washer
The part number is 8182119 and can be viewed at searspartsdirect.com. Just type in your model number and look for item number 5 under the "Door and Latch Parts" heading. In addition, you may not need them, but just in case, you may consider the inner and outer bellow clamps that hold the door seal in place. This are items 6 and 14 under the same heading. Sometimes they become damaged. If you need instructions on how to replace the door bellow, the following link explains:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions along the way, please let me know. I hope this helps you.
NOTE: You can find this part a little cheaper at appliancepartspros.com. Just use the "Search By Part Number" selection as your search criteria.
To keep the new bellow from mildewing, it is recommended by the manufacturer that you leave the washer door open while not in use and to periodically clean the bellow. Pull back the rubber folds in the door and make sure you do not have anything stuck that will cause odors and mildew. Small garments such as socks and underwear can commonly get stuck in this area of the door. Also, if you do not routinely use hot water, it is recommended that you run a "clean" cycle with a small amount of bleach about once a month to kill any bacteria.
SOURCE: push the buttons but doesn't respond
sounds like a fuse iside the dishwashers consol.
access the consol area and ohm out the fuse.
what is your model number?
SOURCE: kenmore super capacity 3.5 washer won't begin washing
Same thing is happening with mine, what did you do to fix it?
SOURCE: Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
