SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
SOURCE: whirlpool dishwasher Model ADP8966, fault code 2?
Hi.
F2 means Touch Panel Failure - Replace the Touch Panel.
Try first tripping the circuit breaker and see if this can clear the error.
Parts must be tested before replacement.
SOURCE: please could you tell me what an F4 fault is on a
f4 fault on a whirlpool ADP5966 dishwasher means (1)Not draining or water level sensor not working . there might be blockage in the drainnage . find
the blockage and remove the blockage. Other problems can be wiring or problems with the control board.
hope this helps pls do let me know
SOURCE: Whirlpool Aqua Steam dishwasher, coming
You have actually posted your Dishwasher problem onto the (garment) Washing machine forum!
However I have checked my Whirlpool list for dishwashers and for some models 'F4' stands for 'drainage' (as you have checked) but for others it mentions (quote) 'no heat, relay, NTC (thermostat), connections, underfilling are all possible'(unquote).
When there is an NTC problem with washing machines we often suggest pouring the contents of a couple of boiling kettles into the washer as it sometimes kicks the NTC into life! Might be worth doing that with your dishwasher before calling for service ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
