It's possible the thread sensors are dirty.
It is likely you have the bobbin tension and/or upper tension not set properly. When your foot is down give the bobbin tension and upper tension a tug. The amount should be equal with each other but not so tight to test the thread for strength. In others words you may have to loosen the tension or tensions. Also, be very sure that your upper tension has the thread going between the tension plates.
SOURCE: Bernina Bernette 600 Deco embroidery machine
It could be that there is a loose piece of thread, or some fluff which is obstructing the tension gauge. Try blowing around the theading area (or even run the hoover pipe near it to see if you can **** it out). I cleared mine by folding a piece of non fluffy material and rubbing gently between the tension dial and machine.
Good luck
SOURCE: my macine is new and i cant fix the bobbin tension
the problem is always on the other side of the fabric - if thread bunches up underneath, the top tension or threading is wrong
SOURCE: Stitch tension problem - bobbin
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
SOURCE: I keep getting "check and rethread the upper thread" error message
Hi....I also kept getting the check and rethread upper thread message, I\'d sew about 15 stitches and it\'d stop. Here\'s what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slit in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slit in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would\'ve ever that it\'d be so easy and save me a bunch of money!!! I sure hope this helps someone.
