SOURCE: how to connect wifi network in archos 28 internet
This
is normal. To save energy, the ARCHOS always starts up with the WiFi
set to off. You must manually use the Fn-F3 keys if you want to
activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong?
Make sure that your WiFi is activated. This can be turned on and
off with the blue function key pressed down and then the F3 key. The
blue WiFi indicator just below the touch-pad will light indicating that
it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong?
It could be that the WiFi modem/router is hiding its SSID. This is
done for security purposes sometimes. You can either change this on the
WiFi modem/router (see its instructions) so that it broadcasts its SSID
(and then you'll see it in the list on your ARCHOS 10) or you can go
into the advanced settings of the Wireless Network Connection screen to
the Wireless Networks tab and 'add' a new connection. You will need to
know the SSID name and its other connection parameters.
SOURCE: Samsung tablet isn't connecting to
Go to Settings, Data Connections, Mobile APN and press Menu.
Then choose, reset to defaults.
It will take a minute or so, but after that 3G should ve enabled once again.
Hope i was of any help. If so, please rate me.
Thank you,
PcSimples
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12
mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to
gather around on the sofa at home or slip into a carry case for when on
the go".
Archos Arnova 10 G2
SOURCE: my internet tablet keeps saying network problem when i try connecting to wifi
Please check your password and see the strength of the WI-Fi in your area. If this a wifi of your home wireless modem then check the modem and reset accordingly. switch off power for some time and restart.
If not check your tablet on another wifi to confirm this or if the configuration has gone off from the settings.
make sure that your password and the network is connected as seen on the lower taskbar .
