SOURCE: my sidekick 2 camera won't work (someone please help)
There is a hardware problem with some SK2's that involve the top bumper and a brownish ribbon cable under 2 tabs. here's the hiptop forum (the manufacturer) where the problem is discussed,a nd the solution is copied and pasted below. http://www.hiptop.com/forums/viewtopic.php?t=22867&highlight= the problem is that the plastic clips that hold part of the top rubber bumper push on a cable inside the unit. if you take off the top rubberized bumper you will see a orangeish yellow ribbon cable. this is whats getting hit. here are some CRUDE pics i just drew up just now. no laughing! labels these two show what happens after pressure is applied to the area around the sim slot. I found that if you take off the bumper and LIGHTLY massage the side of the cable in with a paperclip (CAREFULLY) and then try the camera untill it works again. then to prevent this from happening again... I cut the clips that go into those holes. no clips.. no issue. ive done this for my freinds and they love me now.. they call it the clip snip. Ive fixed 7.. no 8 cameras so far this way. no where near a software issue. I cannot recomend that YOU sticka paperclip inside the unit unless you know what youa re doing. I can only recomend that you try removing the top bumper and waiting to see if the camera ever comes back. if it dies then snip the clips that go into the hole above the camera cable. let me know if this makes sense to you or not so i can edit.
SOURCE: nikon D80 "CHA"
Margie,
When you say it won't let you put it in, do you mean it won't fit in, physically or just that the CHA is on when it is in? If that is the case, you might look at the card and see if it is in 'locked' mode. If it is, it has to be unlocked before the camera can take a picture using that card. Also, your camera's information is available online from Nikon. Here is a link to the Owner's Manual for your camera body:
http://www.nikonusa.com/pdf/manuals/noprint/D80_noprint.pdf
If you want a printable version, you have to provide the website with your camera's serial number. You can do so here:
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?p_faqid=14051
SOURCE: what's the biggest micro sd card that fits htc s 620 smartphone?
Hope this helps, if it does please rate accordingly,
David
SOURCE: how much of GB micro SD card does htc tytn-2 support ?
technically speaking 32 Gb is the limit but the only size Max that is available is 8Gb Type is MICRO SDHC and Sandisk or Kingston both are good brands PLS RATE ME FIXYA FOR HELP
see this on EBAY
http://cgi.ebay.com.au/8-GB-SanDisk-microSD-HC-fits-HTC-Touch-TyTN-ii-S710-8GB_W0QQitemZ380108918426QQcmdZViewItemQQimsxZ20090307?IMSfp=TL090307174001r21751
ppl use and confirm here see this link
http://www.htcwiki.com/thread/1725456/Micro+SD+Card?t=anon
SOURCE: phone is no longer reading my sd card on HTC Hero
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
