SOURCE: Dishwasher (whirlpool quiet partner II)
I think I solved the door leaking problem by cleaning out the plastic filter screen on the inside (left) door panel. Didn't even know it was there, never knew it was suppose to be cleaned! It was so clogged and gross. I also discovered that my washer had shifted and was off balance. It has wood shims under the steel casing and one block was loose. No doubt from slamming and banging the door open and closed. Had to take the front skirt and kickplate off to see. I had my son use a lever and hoisted it up a little while I replaced the block shim now making the washer level again. Ran a light wash before fixing problems and it leaked. We ran a light wash after the fix's and so far so good. Haven't ran a regular longer wash yet. My water level was fine, no gasket problems, no washer wand cracks, etc... My husband was thrilled! When he came home, I informed him I have good news and not so good news. The not so good news was dinner was going to be late, the good news was I fixed the leaking (for months!)dishwasher and saved alot of money on repairs!
**Cleaned filter screen, made dishwasher level again.
SOURCE: whirlpool dishwasher QUIET PARTNER II doesn't
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
SOURCE: How do u unlock the whirlpool quiet partner II
Hi, these dishwashers have a child safety lock so kids can not play with them. To unlock, just push and hold any button for 5 seconds to unlock.
SOURCE: my whirlpool dishwasher soap dispenser is
Symptoms:
Dispenser lid is open. Caked powder at (what would be during normal
operation) bottom edge of soap dispenser or caked powder fallen onto
dishes or dishwasher bottom. There may be loose powder in rest of
dispenser or spilled down inside door or onto dishes underneath
dispenser.
Solution:
Keep the area around the soap dispenser lid clear when loading the top tray.
Explanation:
The soap dispenser needs to swing open during the wash cycle. In many
dishwashers the top tray has an indentation as wide as the lid of the
dispenser. This allows the top tray to be as large deep as possible
while still allowing space for the dispenser lid to open. People often
pack their dishwasher with things overhanging this gap.
During the wash cycle the catch will release but the overhanging cutlery
or crockery prevents the lid from opening all but a few degrees. Some
water will splash in but not enough to wash out the soap powder. The
soap powder at the bottom of the dispenser will then cake.
When the front door is opened the spring loaded lid, which is partly
open, will of course swing fully open and you'll be convinced that the
lid opened normally during operation. If this is the problem then if
you're very careful and open the door very slowly you can actually hear
the lid flip open. Also, depending on when the lid opens, how far it
opened during operation and how fast you open the door you may find soap
powder spilled down to cover the dishes at the front or down the inside
of the door. This happens when you first open the door and obviously
there couldn't be loose powder there if the powder had emerged while
there was water washing around. Seeing the lid open as you open the door
is a lot harder but can be done on some machines.
