So my issue started when I lost micro sd card, Android 2.3.3 won't allow play store so I'm wondering can I use my pc and download the apk file n transfer to internal memory or I've read the phone can be used as a webcam and I could probably just add the camera to my athome set up but I'd prefer the app
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
SOURCE: how much of GB micro SD card does htc tytn-2 support ?
technically speaking 32 Gb is the limit but the only size Max that is available is 8Gb Type is MICRO SDHC and Sandisk or Kingston both are good brands PLS RATE ME FIXYA FOR HELP
see this on EBAY
http://cgi.ebay.com.au/8-GB-SanDisk-microSD-HC-fits-HTC-Touch-TyTN-ii-S710-8GB_W0QQitemZ380108918426QQcmdZViewItemQQimsxZ20090307?IMSfp=TL090307174001r21751
ppl use and confirm here see this link
http://www.htcwiki.com/thread/1725456/Micro+SD+Card?t=anon
SOURCE: file transfer problem from phone memory to micro sd SGH- D780
samsung D780 sucks when it comes to accessing the memory card. i have the same problem too.
SOURCE: I have htc smart f3188
Hi
Go to the blue tooth open the setting and select the storage device --Memory Card, Now automatic your file will save in memory card in Received Folder.
