Hi guys
I want to know how to reset my chromecast audio, Please help us regarding this issue, I need a solution because I want to reset my chromecast audio as soon as possible.
Sable Fur Eyelashes Factory Sable Fur Eyelashes Factory From China Best Mink Lashes ManufactureWe are China Top mink lashes manufacturer and Sable Fur Eyelashes Factory, you can get the most natural, soft and comfortable mink lashes directly from our lashes factory with wholesale price. We supply OEM/ODM Service for mink lashes,custom packaging are accepted. Worldwide shipping and free sample is Available http://www.sheafferlashes.com/sable-fur-eyelashes-factory
Hi there, keep in mind that the Chromecast audio will be delivered through the TV itself, so it does not matter what DVD or audio equipment you are using, so make sure that your TV's audio is turned up.
If you do want to route the audio through you amp, you will need to use the TV's audio out and feed that to your AV receiver to play through your big speakers.
Hope this helps, let me know if you need more help.
Hi, this could be a power issue, are you using a USB port on the TV to power the Chromecast?
Some older USB ports might not have enough power capacity in which case you should use the small power adaptor that came with your Chromecast and power it from a wall socket.
Ensure that wireless isolation (or any labeled form of network isolation) is disabled, though it shouldn't be enabled unless it was manually set that way. I've also run into this issue when setting up Chromecasts occasionally, and I had to do a factory reset (hold down the small reset button on the Chromecast for 30 seconds) and repeat the setup process in order for it to be detected. You might try that as well.
hi marco, the problem seems with the switches on the face. make sure that ALL switches have a "click" sound when pressed down. if not then that switch needs to be replaced. faulty switches can cause the face functions to work erratically. to try another route use your unit with the wireless remote control to check if all functions work well. cheers.
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Try disconnecting it from all 12 volt sources(overnight)to reset the code entry procedure. If that dont sort it, let me know and we shall try something else
