Most likely, the main control board of the washing machine was damaged by the power surge that melted the plug. Additional wiring damage may have also occurred. The damaged electrical parts will have to be replaced.
Please add a comment with the model number of your washer if you'd like a parts diagram and price list for your machine. The parts diagram for one Bosch Maxx7 model, WAE28490GB,
is available here: http://www.bosch-home.co.uk/customer-service/care-protection-and-parts/WAE28490GB/01#/TabsTogglebox=spare-section-3/ . See diagram 1/5.
Your homeowner's insurance may pay for the damage, under some circumstances. It isn't covered by the Bosch warranty.
SOURCE: inlet/ drain light keeps flashing
You have a leak and the bottom pan is full of water. You can remove the cover at the bottom front of the dishwasher and see if the bottom pan is filled with water.
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
SOURCE: Hotoint WMA34 door light keeps flashing and machine wont start
The light flashing usually indicates that the door is not closed securely. this can be caused by a weak or broken door handle spring.
If you are satisfied that the handle is o/k, then the other possibility is that the control module has a blown track, this can be accessed by removing the top cover.
Hope this nhelps.
SOURCE: r7184b just got oil reset wont reset tried main
if the reset is a square button see if this will work. hold the button in, the green light will go out, count to 30 by 1000s, (1001-1002-1003 etc.) at around 1030 the green light should flash once. when it does release the reset and wait about 10 sec. the pump should start. if it runs for about 15 sec. and shuts off the pump needs to be bled. good luck, hope this helps.
