SOURCE: How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17. I clicked down the on switch and it stayed down. However, the light and power together seemed finicky. That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up. When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have. It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have. So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle. I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each. It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch. There are two wires that both turn on the light and power the heater element. Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center. When the switch is pushed down, you can see these two tabs move. They are each moving to touch a contact and complete the electrical circuit. My problem was they were not making a good contact. The contacts are hidden behind the tabs. All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact. The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this. Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
SOURCE: kettle shuts off before boiling?
I had a similar failure. Switch it on and the lights flicker and go out before it boils. Took it apart (Tamper Proof TORX, available from Snap-On, Canadian Tire, probably most auto parts places that also sell tools). The On-Off switch has a mechanical lock out for the lid being open and also for when it is not mounted on the base. The kettle also has three bi-metallic temperature switches. One shuts off the kettle after it has boiled long enough. The other two sit up against the element assembly adjacent to each end of the heating element.They protect against boiling an empty kettle by sensing the higher element temperture when there is no water to conduct away the heat. In the case where the lights flicker and go out, but the switch stays 'On' these are the likely culprit.
In my kettle the contacts did not line up correctly. Instead of making good contact they were only partially overlapping like a couple of the olympic rings or a couple of rings from the Audi logo. This resulted in a localized increased resistance and high heat in one of the contact holders which eventually melted the surrounding plastic. At that point the wires going to the element behaved a bit like springs which forced the contact holder further out of alignment until it all became hot enough to trigger the thermal switch.
I fixed it by bending the contact holder, which is fused into the now hardened plastic, to the optimal position and hopefully it will not generate enough heat to remelt the plastic or trip the thermal switch.
I have boiled a couple of kettlefuls; so far so good!
What ticks me off about this is that I don't mind getting 'Made In China' ****; everything comes from China anyway. But don't charge me a ridiculous amount of money and try to pretend that I am getting a superiour product. If I had paid twenty dollars or less for it I would just chuck it and get the same one again because it looks nice, pours well, doesn't burn the hands, worked OK for couple of years, etc. Instead I walk away from this feeling really ripped off. I have a house full of Braun products(shaver, kettle multiple tooth brushes) but now I won't buy any more.
Oh and if you take your kettle apart and your house burns down it is not my fault. There, now I feel better.
SOURCE: Why does the water boiled in this kettle smell and
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Testimonial: "Glad to hear it's not my imagination. On complaining to the retailer they suggested that I have a very delicate palate, or do I have fillings in my teeth!!! I do, but my 85 year old mother sure doesn't. Thanks again."
SOURCE: My Braun electric kettle won't click on. Do I
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
