Http://support.brother.com/g/b/manuallist.aspx?c=us_ot&lang=en&prod=mfcj435w_us&flang=English&type3=124&type2=8
Setup Guide Manuals MFC J435W Others Brother
http://support.brother.com/g/b/manuallist.aspx?c=us_ot&lang=en&prod=mfcj435w_us&flang=English&type2=5
User Guide Manuals MFC J435W Others Brother
SOURCE: Users Manual
Hi Here is the direct link to the user's guide manual: http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=mfc3420c_us&type2=5&flang=English&dlid= Hope you find what you're trying to look for. Thanks, Lolita
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
SOURCE: brother MFC-210 user guide
I cannot locate my user's guide but my printer says unable to print.I should look under routine maintenance. Help
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing.
thanks
