Start by going to “Contacts” and tap on the contact you want to block. Then, press the menu key at the top left of your Doro 6520. You will see a menu where you will select “Block Number” or “Add to Auto Reject List”. The title may vary depending on the model you own
Testimonial: "There is no block number or reject list"
then what comes up when you're on the phone number you want to block when you push the menu key in the top left top right?
Call, View, Send SMS, Send MMS, Delete, Save
o you have to do it in your text messenger same way I was telling you to do it in your phone settings
How do I do that when someone has called you
So your text message application like I said on the first one with the phone numbers you have to do it in your text messaging
